Brand: Whirlpool Model Number: wtw4800bq1 Main Symptom: Lid Lock not locking What happens & when:
Parts or tests already tried: Lid Lock, Control board
So, this washer starting acting up a few months ago, would sometimes stop in the middle of cycle or not fully drain. Replaced the drain pump, worked a little better for a bit, but then started acting up again. Then last week, fully stopped working, just had all led lights on and drain pump running. Even if you unplugged it and then back in, immediately all lights and pump running. Thought maybe lid lock, so installed new one, no change. Determined must be board and which I confirmed in that upon removed the board, I found a hole blown in the micro-controller and several blown smd resistors. Ordered replacement board from shopjimmy. Installed and I first thought all good as when I plugged it in, no lights or pump running. Went to do a recalibration, but wouldn’t start as the lid lock wouldn’t engage. You can hear the relay clicking, Lock LED flashing, but lock itself not engaging. Went into manual test mode, same thing, just the relay clicking, etc. Thought I got a bad board, exchanged for another. Same thing. I tried original lid lock, no change. I even tried unplugging everything from the board and just left the lid lock connected, still just clicks the relay and never engaged the lock. I am going to get my multi-meter tomorrow to do some further testing, but anyone have any other ideas on what is going on?
Did the new lid lock come with a new bezel and was the new bezel installed along with the new lid lock? If it was, I’d suspect either a bad strike WPW10240513, or the lid WPW10338625 or top WPW10251299 is warped/bowed slightly and not allowing the lock to engage.
It did come with new bezel and strike. I replaced the bezel, but not the strike. But even if I put the new strike into the slot by itself for testing, the lock never engages.
So after putting a meter on the lid lock, it comes back bad. I think whatever blew on the original board, caused a short on the lid lock circuit, frying the solenoid, and since I replaced the lid lock first, I killed it before trying the board. I took apart the original lock and the solenoid smelt burnt. Got a new lock coming tomorrow, fingers crossed.
So, to hopefully round off this thread. I put the new lid lock on and the lock functioned in manual mode. Started a calibration cycle and it failed. Started testing in manual mode and spin cycle was failing. It would start up for a second and then error out to F7E1. Tach verification also failed, so I assumed the blown board also took out the optical sensor. Installed new shift actuator and spin worked and calibration cycle completed w/o error. Finger crossed again that we can do laundry tomorrow.
