My timer knob doesnt want to turn the control dial anymore.if i press on the clear plastic dial and spin by hand it works,but not from the knob itself,is there something behind the knob that wears out or strips?
The timer knob almost never fails on these models, but try changing it out anyway. It is not expensive and that may fix your problem.
Thanks for the reply,i pulled the console cover off today,noticed a plastic peice protruding from rear of timer, seems like it runs all the way thru timer, was told it is what holds knob on,cant seem to get it back in and holding,also noticed a small plastic pin behind the knob looks to be broken off,looks like it is what makes the dial turn when you press in knob,what is the deal with the piece in rear of timer?![]()
[quote=JRIC213;656259]Thanks for the reply,i pulled the console cover off today,noticed a plastic peice protruding from rear of timer, seems like it runs all the way thru timer, was told it is what holds knob on,cant seem to get it back in and holding,also noticed a small plastic pin behind the knob looks to be broken off,looks like it is what makes the dial turn when you press in knob,what is the deal with the piece in rear of timer?![]()
The piece in the rear is what releases the knob, seems like that may be your problem and you may end up having to replace the entire timer. Hope not.
