Whirlpool thin twin dryer belt instulation
anyone know how to install a new belt on the dryer section of this thing
I have pulled off the front panel, and found the belt to be broken from oldness and cracks
the belt is long so for sure it goes around the motor then the drum but is there a set ram or something that I need to calibrate.
thanks guys
You can find the complete instructions in the Service Manual.
In order to provide the right part number for the belt we need the complete model number of the unit. You can find it on the dryer door frame or on the dryer door inner panel.
Thank you so much!!! After frustrating days of web searching and trying to figure it out on my own, I hit on your “answer” and finally have the information I need. I have bookmarked you for future reference. Thanks so much for the help.:slight_smile:
