Whirlpool suds and f-35 problem
I own a Whirlpool mdl # WFW9500TW01 Duet Sream front load washer.It recently started to display a “suds” and “F-35” code. All symptoms point to a new pressure switch needing replacement. I’m trying to get the correct part # for this switch. In doing some searching, I’ve found the whirlpool part # W10156252 is an old part # and the new one is #W10415587. Can you please tell me which part # to order? My other concern is that I’ve heard Whirlpool had a backorder for this particular part. Is this part readily available?
I did clean out the air trap and found a pencil or two. Can you think of anything else I can do to get this machine running again?
Call APP and check with them on the part and the availability. It will probably be the least cost of any parts supplier, they will get you the right one, shipping is very reasonable and if it does not fix your problem you can return it.
How can you do any better than that?
No, those of us who reply on this Forum do not work with, for or are associated with APP.
