Whirlpool stopped working mid cycle
Last night started a normal cleaning cycle. The Clean light was not on and there is water still in the tub. Dishes were not clean, but soap dish was empty. Verified circuit breaker was not tripped, dishwasher still plugged in, and electricity to outlet… but none of the buttons on dishwasher work.
Cannot find anything in troubling shooting portion of manual or online.
Any recommendations are appreciated.
Could not find any info using listed Model Number
But did find info on a DU945PWPQ0 below is info on that unit
Parts
Model DU945PWPQ0
Tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535431.pdf
Most likely the thermal fuse or a door switch
Thanks for the tips. Found that when it was installed the wire connector was not secured appropriately and the connection melted and broke the circuit. I cleaned up the melted mess, stripped the wires and reconnected, and all is working well.
