Hey Everyone,
I had a Whirlpool Soft II with a leak so I bought a replacement pump and changed it out. No problems. Except, after I changed it I went to put the cabinet back on and noticed that the drum was WAY off kilter. Leaning at least a few inches to the right. I could manually correct it, but obviously it falls back out of place. I finished putting everything back together so I could test the pump (no more leak!), and see if the fact that the drum is badly out of balance would cause an issue when I tried it on spin (it agitates fine, it spins like a log truck rolling down a mountain).
So something must of come loose. I can’t see anything wrong with my very untrained eye, but I’m wondering if y’all could help a girl out with some suggestions. One thing to note is that I did tip the washer up on its front when I was initially trying to figure out the leak.
Thanks so much!
Edit: So, I fixed it myself. Seems the drum got knocked out of alignment somehow and I disassembled it again a gently tugged it into the right position until it just clicked right into place.
