Our appliances are 17 months old. All whirlpool gold series. Our microwave burnt up last week and now my oven is out. My wife tried the self cleaning mode yesterday for the first time. About half way through the cycle, the oven quit working. The lights doesn’t work and the door is locked. After letting the unit cool, I flipped the breaker off and let it sit for a few minutes. Turned breaker back on and nothing still. I now have the breaker off and removed the oven from the wall. It is sitting in my kitchen floor with the top panel removed as well as the rear panel. I don’t see but one thing on the top that looks like a fuse and it appears to be good. Its all clear and pristine looking. Where do I go from here? A shame these appliances are only 17 months old. I appreciate any help I can get.
Your model number is incomplete so I have used WOS92EC0AE00
Parts for Whirlpool WOS92EC0AE00 / - AppliancePartsPros.com
It could have blown the thermal fuse (item7 in section 04).
There will not be a visual indication that it has blown.
With the power off remove it and check it with a meter, should be 0 ohms.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
WOS92E.pdf (1.2 MB)
i put a new thermal fuse in and the door unlocked and all power came back up. I thought I was in good shape. Today was the first day we needed the oven and it won’t heat up. I assume the element is burnt up?
I am assuming that the unit stays in preheat.
If the oven shows it is ready then it could be an oven sensor problem.
Does broil work?
If not then check the power at the unit.
The elements need the full 240 volts.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
If OK check the thermal fuse (thermostat) (item 18 in section 01).
This kills power to the elements.
If OK then odds are that the control board is toast.
it does stay in pre heat mode. it appears to only have an upper element. Broil does not make a difference. the digital display and lights all work fine it just will not heat up
If you cannot see the bake element on the oven floor it is probably under a cover.
Since the broil element does not work I do not thing that a burned out element is the problem.
[QUOTE=denman;861563]Your model number is incomplete so I have used WOS92EC0AE00
There is a good STICKY at the start of this forum about it’s use.[/QUOTE]
I have the same exact problem. My oven is this model WOS92EC0AS, single wall oven. I ran the self cleaning and after 3 hours, everything went off. The door locked, unit does not turn on, control panel is off.
I understand I need to probably replace the thermal fuse in the control panel, but how do I actually remove the control panel to get to the fuse?? The oven is still in my wall and I’m not really sure how to get the oven out of the wall with screws not very accessible with the door locked shut. Is there a screw somewhere for the control panel that’s accessible while the oven is still in the wall?
