whirlpool side by side
i have an in the door ice maker/water dispenser that has quit dispencing water. It dispences ice fine,and i have changed the water filter,and checked line for kinks. it is a second home,not used but 2/3 days a month bu us…any suggestions?
Do you hear a clicking when you press the lever for water? If not the switch or lever may be broken in the dispenser.
Can you post your model number?
Nat
[quote=libertyappl;33524]Do you hear a clicking when you press the lever for water? If not the switch or lever may be broken in the dispenser.
Nat[/quote]
no,no noise when pushing lever…i am not at the house now,model unknowm..but only 3 years old,and it has worked up until 6 mo’s ago..
It’s probably not going to take a lot to fix. when you get back to that house post your model number.
Nat
