My Ice maker is putting out ice but at a slow pace but it is spilling water out of the front corner of the ice makers front tray like a 1/4 inch frozen stream. Do I need a hole ice maker or is this an adjustment issue???
Thanks, Jim
Thanks, Jim
[quote=jimmydye@ca.rr.com;463349]My Ice maker is putting out ice but at a slow pace but it is spilling water out of the front corner of the ice makers front tray like a 1/4 inch frozen stream. Do I need a hole ice maker or is this an adjustment issue???
Thanks, Jim[/quote]
Jim,
You can try and adjust the water level, it will work for a while, but you’ve most likely have a “sticky” water valve and it’s allowing the icemaker to slowly overfill, and causing the icicle.
With the white plastic cover removed from the front of the assembly, you should see a white plastic screw slightly protruding from the side of the mechanism. you can adjust the level lower by turning the screw in a clockwise direction 1 or 2 revolutions (3/4 to 1 turn would probably be sufficient).
I take for granted you’ve already checked for good water supply to the fridge and a clean water filter( if applies).
Good Luck,
