Frame inside between fridge and freezer is hot to the touch…I did take the front panel off and tried vacuuming the coils. It is not cooling in the fridge and the freezer is not freezing.
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Replacement parts for WHIRLPOOL ED25QFXHW00 SIDE-BY-SIDE REFRIGERATOR | AppliancePartsPros.com
Pull the unit out and remove the rear cover.
Check/clean the coils from the back.
Check/clean the condenser (compressor fan). It should be on when the compressor is on.
If the above are OK and the compressor is running but you get no frost/cooling on the evaporator (freezer) coils then you have a sealed system problem.
This will be an expensive repair as you need a pro. Also there is no guarantee of a long term fix. Usually it makes more sense to put the dollars towards a new unit.
