Whirlpool Side by Side Door Handle
Door handle on refrig side is loose. How can I tighten it or replace it if required?
Here is your parts breakdown
Model GS5SHAXNB00
Looks like you pull upward on the handle and it should release from the retaining clips
Thanks for the info but I tried to push upward but NO GO. Again thanks!
If you look at Item 5 the clip in the "Refrigerator door parts " section
You can see there is a small clip that holds the handle’s bolt i the clip.
You may have to use more force while having another person hold the door down..
Perhaps someone else will know a trick to release the handle.
Two people did the trick. I hope it goes back just as easy. Thankyou!! Fixed!!! Thankyou again!
