Whirlpool Self-cleaning has no power
Put oven into self-cleaning mode. It kicked the breaker after about 40 minutes. Turned breaker back on but still no power to the oven. I was able to push the solenoid to get the oven door back open.
Any ideas on why there is no power to the control panel?
[QUOTE=maddogmdf;300972]Put oven into self-cleaning mode. It kicked the breaker after about 40 minutes. Turned breaker back on but still no power to the oven. I was able to push the solenoid to get the oven door back open.
Any ideas on why there is no power to the control panel?[/QUOTE]
It sounds like the control panel shorted out, and blew the breaker. But the is a thermostat in the back, you can jump out to be sure. I would, because the control board is no longer available. The thermostat part # is 4450934. You have to pull the oven out of the wall, and take the back panel off, and of course you have the power off, when you do this. The thermostat is right in the middle of the back, and has 2 wires coming to it. Take the 2 wires off, and put there terminal ends together, and put some tape around it to keep them together, and to cover the terminal ends from hitting metal. Then turn the power on and see if the board lights up. If you have an ohm meter, take the wires of, and see if you get a ohm reading if, so it is good. If not it is bad. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
