Model is RBS305PDB4, Accubake Self-cleaning oven. Bottom element won’t heat, top heats fine. I have replaced the bottom element, and checked continuity on the Thermal Fuse; it appears to be OK.
Any ideas? Thanks for the help in advance!
Replacement parts for WHIRLPOOL RBS305PDB4 | AppliancePartsPros.com
Here is a manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d69e72584ddde3385256a7e00524e76/$FILE/8178007.pdf
Looks like the thermal fuse would have removed power from both elements.
Did you check the bake element with a meter before installing it?
Getting bad replacement parts does not happen often but it does happen and can get you running in circles to find the problem.
The only thing I can see in the circuit that would cause it not to come on is the control board or a bad wire/connection.
I am assuming that the unit does not show that it is ready.
