Whirlpool Replaced Controller and can’t enter code
Brand:Whirlpool Refrigerator
Model Number:GI0FSAXVY012
Main Symptom:Not Cooling after Replacing Contol board in back but can’t enter Reset Code because front panel is not working. And replacement front board W10901007 on back order 7-14 days. Is there another way?
Error Code (if any):PE0000
Without the display not working then you would need to get it replaced to program the unit.
Hi, just got the replacement board W10708467 that was back ordered and installed it and powered it on and got the same error PE0000 and tried to push and hold the Water button and LL to reset and enter the code but nothing happened. Initially the error code was flashing but now it’s steady. The only buttons that work are the UR UR and the light button. The fridge was off for a week so it had time to reset. What do we do now? Thank you.
Sorry I have not heard back
