Brand:whirlpool
Model Number:wrb322dmbwoo
Main Symptom:freezer cold refridge warm
Parts or tests already tried did self diog put in forced defrost no power coming out of board to derfrost htr ohmed out htr 29 ohms, bypassed control power htr directly 4 amps ,replaced board set code to 01 per data plate ,still cannot get power through the board in forced defrost,also ohmed out defrost tsat closed, same problem as before board replacement
