Whirlpool Refrigerator
Whirlpool side by stopped working.Lights work,but fan, compressor don’t.There is a constant clicking in the plastic box on side.Any help would be appreciated.Model gs6shexml00.
Replacing the start relay will probably fix that problem
I would remove the back panel of the fridg. and check where the noise is coming from. If the compressor, you can try a new start device on the compressor, however GE start devices rarely fail. If it’s coming from the pc board, it’s probably bad. Order here AP4334000
Thanks Qtip I read somewhere to shake the relay ,if it rattled it was bad.It doesn’t rattle.I’m thinking it is probable the pc board,since the clicking is coming from there.Or not??? AGAIN THANKS FOR YOUR INPUT…
I would follow richappy’s advice he knows much more than i do.
Replacement parts for WHIRLPOOL GS6SHEXML00 Refrigerator | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%202255955.pdf
Since both the the condenser/compressor fan and the compressor do not run odds are high that it is a problem with the control as they are wired in parallel.
OR
the fan also has a problem.
OR
the voltage is low to the compressor for some reason. If the unit has the capacitor, try running without it. Would be a good idea to measure the voltage across the fan.
Could be that you are stuck in a defrost cycle. If this is the case the evaporator fan will also be off.
Try running the diagnostics.
Thanks denman and richappy.The pc board did the trick.I ordered the part Monday afternoon got it Tuesday afternoon. Installed it Tue. evening and the cold air started flowing..Thanks again guys for the info It’s very much appriciated.. Bigike
