Whirlpool refrigerator WRS321CDBM intermittently stops cooling
I looked into that but if it was cutting out the compressor the condenser fan would still be running because the red power wire daisy chains from compressor plug and continues on to the condenser fan and I used a meter and the power going to compressor form control board is being shut off like the fridge thinks it has reached temp setting. Thanks a ton for these documents though! I had the parts list and wiring diagram on paper that came with the unit but needed a magnifying glass to read it and I couldn’t find the service sheet that tells me how to enter diagnostic mode so I will use that tomorrow to see if the fridge might tell me what has failed. Very much appreciate your help bigbuck!
