Hi, my refrigerator has a water leak from the water dispenser in the front where at random times it will just start dripping water even if you lock the water it still keeps dripping. Ive tried taking the filter out with no luck so please somebody help me with what the problem could be and what i need to do or purchase to repair it. Thank You
Hello,
Sounds like the problem is a bad water inlet valve on the back of the refrigerator.
In order to replace the water filter follow the instructions from the Owners Manual.
The model number you posted does not come up. The closest model number I found is [MODEL]ED5FHAXSQ01[/MODEL]
