water dispenser problem.water DOES come out of tube for it but sprays from other area around the tube also & I don’t know how to get that section off to look up in it to see where it’s leaking from
Remove the dispenser front cover as described in the attached file and inspect the parts inside.
Here are the breakdown diagrams and Dispenser front parts replacement parts for WHIRLPOOL ED2NHGXVQ01 REFRIGERATOR | AppliancePartsPros.com
Ice and water dispenser.pdf (406.6 KB)
[quote=Gene;415338]Remove the dispenser front cover as described in the attached file and inspect the parts inside.
Gene.[/quote]
thanx Gene for your help.This fridge belongs to my parents so I will be going down to their house today to see if i can get that cover off & find the problem.A couple of questions though.Is this a common problem with the Whirlpool refridgerators & after I get that cover off, will I be able to observe dispenser as it is functioning to actually see what it is doing wrong???
By your description it does not look like a common problem to me.
