Whirlpool refrigerator not producing ise
Brand:Whirlpool
**Model Number:**gs6nvexvs01
Main Symptom:Ice Maker is not making ice
What happens & when:When the icer maker calls for water, water shoots out around the top water tube on the back of the refrigerator and no water is put in the ice maker. Water is dipensing through the door normally.
Thanks!
If it is leaking at the backside of the fridge where it goes into the cabinet then this will be an issue with the tubing. Here is the part number for the tubing. WP2256096 Ice Maker Water Supply Tube | Genuine Whirlpool OEM In Stock
