Brand:whirlpool refrigerator/freezer Model Number:ED5VHEXVQ03 Main Symptom:No cold air blowing on ice maker What happens & when: very slow cycle to make ice
Parts or tests already tried: Used hair dryer to blow warm air in air damper assembly in refrigerator. No help. Freezer temp at 10 degrees refrigerator at 42 degrees.
For Whirlpool ED5VHEXVQ03, I would not condemn the ice maker yet. Your temperatures point to a cooling/airflow problem first.
Freezer should be roughly 0°F, and refrigerator roughly 37°F. At 10°F freezer / 42°F refrigerator, the entire unit is running too warm. That alone can make the ice maker cycle very slowly. Whirlpool’s parts information also shows this model uses an evaporator fan and an air-flow system to circulate freezer air.
I wouldn’t replace the ice maker until you can get that freezer down near 0°F. The 10°F freezer temperature is the biggest clue here, especially since the refrigerator is also warm.
If you tell me what the frost pattern looks like behind the freezer panel (fully frosted, evenly frosted, or frost only on the first few coils), I can narrow this down considerably.
