Whirlpool Refrigerator Control Board Replacement
Brand: Whirlpool
Model Number: GI0FSAXVY08
Main Symptom: Fan, Compressor, Front Panel not working
About 1.5 weeks ago, the refrigerator’s fan, compressor, and front panel stopped working. When the refrigerator was still plugged in and the ice/water lever was pressed, the front panel’s lights would all come on and a loud beep would occur. Otherwise, only the interior lights were still working normally.
After some troubleshooting, we ordered a replacement Control Board from you all at AppliancePros.com. It arrived today and upon installation, the fan began working, interior lights are working, but the compressor is not working and the front panel is displaying “PE0 000”. The buttons on the front panel are all disabled and when pressed, the light above them does not illuminate. When the up/down arrows on the Refrigerator Temp display are pressed, it toggles between H20 and ICE and water does come out. After some research, it appears that the refrigerator needs “programmed”, but none of the button sequences are working because the buttons are non-functional on the panel.
I have unplugged the refrigerator for 10 minutes, turned off the breaker power for 10 minutes, and unplugged/re-installed the new Control Panel several times to no avail.
I’m wondering if I may need a different Control Panel model? The panel I ordered is Part#: AP6019287 (WPW10312695)
Many thanks for any help you can provide!
Error Code (if any): N/A
Parts or tests already tried: AP6019287 (WPW10312695)
This has to be programmed. I am attaching a copy of the tech sheet which will have programming instructions on it.
techsheet-w10410713-reva.pdf (204.3 KB)
