After a power surge, the compressor stopped running, but all the fans where running. No voltage going to the compressor. This fridg has a relay board by the compressor.
Turned cold control off and unplugged fridg for 30 seconds to enter diagnostic mode. Plugged in fridg and turned control on. Compressor came on. I assumed this action re-set the computer.
Hope someone has seen this before.
I am, based on no response to this failure, of the belief this failure was due to the power surge sparking a compressor wire in the relay board connector as I did pull it out and flex the wires.
