I have no voltage to the ice maker at the ice maker plug behind the ice maker. Where is that voltage coming from? Or where can I get a diagram?
I could bnot find any info on the given model number.
Are you sure that there is not a X between the D and the W.
The following info relates to the GB9FHDXWB02
Here are the parts
Parts for Whirlpool GB9FHDXWB02 Refrigerator - AppliancePartsPros.com
See the attachments for the tech sheet
Looks like you have to hold the freezer light switch in for power to the ice maker.
GB9FH.pdf (257.6 KB)
WOW. Who would have thought the ice maker was coupled through the door switch
A second question
The ice maker was making HOLLOW ice cubes when i took it out. The cubes were hollow but there was no liquid inside them an no extra water in the collection tray. Not sure I can figure out how this happened and how to correct it.
Thanks again for the heads up on the door switch
HowieE
Hollow cubes could be low water flow.
Just search the forum using advanced and tick the Refrigerator section.
Search for “hollow ice cubes”
