Whirlpool Range will not heat to temperature that is set
Brand: Whirlpool Range
Model Number: WFE540H0ES0
Main Symptom: Oven will not heat to temperatue that it set.
What happens & when: When I set the oven to 350, it will not heat past 200 degrees. I tried to calibrate it, but it still will not heat past 200 degrees. Please help me figure out the issue.
Thank yoiu
Does it seem to heat up to about 200º and then quit heating altogether, or does it maintain that 200º?
No, if I raise the temperature to 450 it riases to 300, but it does not hold the temperature.
Does it act like it has finished preheating when it loses heating? Does this happen in bake and broil, or does it only happen in bake? If you haven’t tried broil yet, go ahead and try it to see.
