Whirlpool Range display board turning off
Thanks Jeffrey,
I appreciate the help and not suggesting right off the bat that I buy the new part. I also appreciate getting to me the replacement.
I do question though if i do spend the money, and find it’s not the issue, according to customer service, once I install the part, I am not able to return it.
That would mean I had spent cover $500 and still won’t have a working range, when I can buy the same range new now for $900.
I am not sure there would be many other options, since the oven did get warm when we it was on, the stovetop did work through it all. It seems the only other likely culprit could/would be the new board cited above. Does my logic make sense? I’m asking because you say it’s a strong possibility, but you can’t really guarantee it I imagine.
Thanks again,
Joe
Yes you’re right without actually being there to check the unit I cant give you a 100% recommendation. If you want a second opinion before ordering have a repair tech come check it out
Thank you, might have to do that.
Appreciate the help.
Thanks,
Joe
