Whirlpool Quiet Partner IV dishwasher
Dishwasher will not turn on. Does have power and will run through reset/self test when pressing sequence of buttons. After researching problem I replaced circuit board (ordered from appliance pros). Dishwasher will still not come on and now the normal light just blinks and will not run through reset cycle. Replacement board appears to be the correct one all wiring hooked up correctly. Do not understand why the two control boards act differently and washer will not run. Any help would be greatly appreciated.
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208530866.pdf
Here is a manual which may be useful
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
I would try cleaning the control panel ribbon cable connection.
If this does nothing, check the control panel switches with a meter as per the tech sheet.
[COLOR=Blue]
Do not understand why the two control boards act differently and washer will not run.[/COLOR]
I cannot explain why the boards act differently.
Why the washer does not run could be that you have a control panel problem.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
