Whirlpool Quiet Partner III
The door on our Whirlpool Quiet Partner III dishwasher does not lay flat when opened. It remains opened at an angle and quite annoying. Does the door spring need to be replaced? Any advice is welcomed. Thanks.
It does not sound like a spring problem.
Check you manual as the spring may just need adjusting.
Also check that the unit is installed level.
