My dishwasher won’t run. I push on normal and heated dry and when I push start, everything goes blank. Then if I push start or cancel, there will be a two minute cycle with no water and it shuts off by itself. No water going through the machine. It seemed to fix itself for two days, but now the same problem is back.
So I tried the normal-heat dry trick x 4 and it runs the normal wash for 16 minutes after flashing a d1 in the time remaining window. It also would sometimes blink over to the rinse cycle. Water is moving through the machine. When I try to run it on normal again, the same problem occurs.
