The Sanitized light is blinking after the dishwasher is finished. The dishes are clean but very wet. Any idea what is wrong?
Could very well be a bad drying element. Tom
Replacement parts for WHIRLPOOL GU1200XTKQ0 | AppliancePartsPros.com
Here is a service manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
Check the heater and the high limit thermostat
If you do not have one, I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
