It was working fine one day and then just quit the next. Has an inch of water at the bottom and no power to the panel. I opened it up and there don’t ‘seem’ to be any blown fuses, or loose connections. Help please!
Thank you!
Thank you!
I cannot find any info on the given model number.
Are you sure it is DU1055XTVVQ0 or is it actually DU1055XTVQ0.
Here are the parts for an XTVQ0.
Replacement parts for Whirlpool DU1055XTVQ0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Could be the thermal fuse (Item 4 in Section 1) is blown.
Remove power from the unit.
Remove the fuse and check it with a meter.
Should be 0 ohms.
If not replace it and be sure that you use the new harness that comes with the replacement fuse.
