Whirlpool Quiet Partner II
Dishwasher only works in Light Wash mode…other modes will not work and their led’s do not light.
A model number may help others help you.
Try the following
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
