Whirlpool Quiet Partner II Not Drying
Hi, and thanks for your help!
I have Whirlpool Quiet Partner II - heating element is perfect, but dishes are not dry when cycle is complete. Also, there is no issue with water at the bottom of washer when cycle done. Did some reading, and most suggestions point towards a faulty control board. Is there anything I can try…“reset” or something before I lay out that kind of money?
Thank you so much,
Michael
PS -
A model number may help others help you.
Removing the power from the unit for a couple minutes should reset the unit to factory defaults.
Jello?
