I have been reading this forum and it has been very helpful.
At first my dishwasher stopped draining and I found that the check valve was clogged by a popcorn kernel however once I put it back together the Dishwasher now has a different problem which I think may have been caused by the first
The dishwasher does not complete the wash cycle. It loads water acts like its going to wash the dishes then goes to air dry I can tell because it never dissolves all of the dish detergent whether its powder or a gel pack
I found a reset code which may help with this problem which is
high temp wash - then - heated dry, high temp wash - then - heated dry, high temp wash - then - heated dry,
unfortunately I do not have a setting such as high temp wash what I have is Rinse Only, Light Wash, Normal Wash, Heavy Wash & Pots & Pans
I guess what I am looking for is the actual Reset code or to be told that what I missed was the fact that Pots & Pans is High Temp Wash or if someone has another idea I can try
The Following link is to an image of this unit;
Whirlpool Dishwasher Quiet Partner 2Gnomecities.com | Gnomecities.com
