I have a whirlpool quiet partner 2, s/n F01228373 mod/n DU1055XTVB1
When I press the start button the start,washing,heated dry, and normal lights come on but nothing happens then I hear a click and the lights go off. Very very rarely it will fill with a little bit of water, about 1.5 inch, and then I hear the click and all lights go out. Now I have water in my washer and if I push the drain/cancel button I hear 3 clicks and nothing happens. It’s only about 3 years old but it was here when we bought the house. It worked fine for 6 months or so then started doing this. I’ve rest my breaker, pressed sani-rinse heated dry to reset the dishwasher but nothing helped.
Damn, got a lot of views but no help. Chime in people with any thoughts or ideas
Parts for Whirlpool DU1055XTVB1 Dishwasher - AppliancePartsPros.com
Sounds like a control board problem.
I would check the motor windings, fill valve etc. resistances before replacing it just to be sure something is not overloading the circuit.
You could also try the diagnostics.
DU1055.pdf (244.3 KB)
