Whirlpool Quiet Partner 2 dishwasher
After the last wash I noticed the green light indicating the dishes were clean wasn’t on. After opening the dishwasher I saw that the bottom of the dishwasher was filled with water. I emptied the dishwasher (all the dishes were clean) and tried pressing the Cancel/Drain button but nothing happened. I tried the Light Wash button but again nothing happened. No lights are on and none of the buttons are working.
I looked to see if any plugs in a nearby outlet under the sink (the dishwasher is located beneath the counter next to the sink) and I didn’t see anything unplugged. I have not tried to pull the dishwasher out in fear of doing damage to the dishwasher as well as hurting myself in the process (haha).
This is my mother’s dishwasher and I do not know much about the dishwasher. I’m assuming she has had this dishwasher for about 5 years. Getting a new dishwasher or calling a repair man to fix this one is the last resort because money is tight. I hope to try to fix this by myself.
The model number is DU943PWKTO, the serial number is FM3921736 and the type is 280-2
Please let me know if there is anything I can do to try to repair this or let me know if the dishwasher is a lost cause and a new one is needed so I don’t have to call in a repair man and pay him to tell me to buy a new dishwasher.
Thank you for any help you can give me!!
[quote=needhelp105;275417]After the last wash I noticed the green light indicating the dishes were clean wasn’t on. After opening the dishwasher I saw that the bottom of the dishwasher was filled with water. I emptied the dishwasher (all the dishes were clean) and tried pressing the Cancel/Drain button but nothing happened. I tried the Light Wash button but again nothing happened. No lights are on and none of the buttons are working.
Thank you for any help you can give me!![/quote]
Needhelp,
If you have voltage to the machine , like you think,
And the control board display has no lights and unit does nothing,
You need to start at the door switch(s), control thermal fuse and the control board
You most likely have an open thermal fuse, in the control panel(pretty common).
I’ve attached part numbers for the parts you may need, including a service manual, and the Technical Data Sheet, so you’ll have a rough idea of what to check and the circuits you’ll need to check.
If or when you’re ready and need more assistance, drop us a line.
(click on numbers for info)
AP6012894
AP3115186
AP4367450
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208275305.pdf
Mine is doing the exact same thing, whirlpool also, where is the thermal fuse located, I oprened the control panel and bought an ohm meter, will need a little help from there though. Thanks.
Mark,
Not all dishwashers have a control panel thermal fuse, or the same one.
Do you have the model number, so we can varify if you do, and direct you from there.
But in general, the control panel fuse is in the door switch circuit , from the door switch to the control panel power inlet connector(wire).
And the wires are tan/brown,if you have the same style unit.
(see picture on previous post AP3115186 ).
Drop us a line,
Thanks,
:cool: :cool: :cool:
Joe, Thanks for the ewply, my model number is weird, most part places do not show it, it is DU1345XTV80, that is off the sticker, I did find the thermal fuse, it is round, which is why I couldnt find it. It is bad and I am looking for one local, Thanks Again.
I checked it and the ohm meter did not move, I checked a regular fuse and the neddle moved. Does that mean its bad?
Joe the serial number is FY0904726, it is a whirlpool quiet partner two. Thanks
Mark,
Thanks for the information,
Yes, you have an open thermal fuse, it should have a circuit through it like the other fuses.
It took a while( this is a new unit / less than a year old) but,
Here’s your part number for the fuse,
(click on number for info)
AP4423189
Good Luck,
My problem is the same as needhelp’s. I have the same model and type #'s. I have remove the thermal fuse. Am I looking for any visible signs of an open fuse?
Mpact, Not really, you’ll need a muti meter
AP5641751
to check across the fuse wire terminals
AP4423189
for an “open” or “closed” circuit.
I have the same problem with no lights or power. I have checked the door switches, the thermal fuse, power to the control board, resistances…all good. According to the manual, I disconnected the panel ribbon from the control board, switched on the breaker power with door open, waited 5 seconds, closed door. No response from the drain motor. Manual says control board bad. I replaced the control board. Still no response. Could there be something else to check or could I have a bad replacement control board? Model GU2200XTSS3.
Mnelson, Yes there are a couple of other things to check. First test the touchpad ribbon/keypad circuits, with a multi meter(located on pg.2 of the tech data sheet). You may have an issue there
AP6014717
Also verify the correct voltage at the control board, with the door latch switches open and closed. P2 (blk/wht ) to P6 (wht/blu) should have 120 VAC across the pins, whether the door is open or closed. P4(wht/prp) to P8(tan) should have 120 VAC only if the door is closed and the latch switches are activated(closed). If the voltages are correct and present at the proper times, then reset the control board, and replace the control panel.
I actually tested the original panel and found the Delay switch open. So I replaced it. On your advice I tested the new one and it is all good. I tested the voltage at P2 and P6. At first it was 2.0 volts and P4 to P8 was 2.0 volts. I had 120 VAC at the thermal fuse and door switches, but I never checked them to P2, only to the chassis. But now no 120 at them. Going back to P2 and P6 I now get 12.7 VAC. Then out of the blue I have zero. No 120 nothing. I go to the junction box where there is zero volts, nothing. I now go to the recepticle under the kitchen sink. There I find the plug half out of the socket. A sink water line ran behind the cord close to the plug. Apparently, over time the vibration from the water line pulled the plug out. So there it is. I feel pretty stupid right now.
Mnelson, Great move, Great diagnosis/procedure. You found a voltage issue at the control, you traced it back to the power supply. That’s the way it’s done, sometimes. Great job.
Hello all..
I’m having the same problem, model #DU1055XTVDB. The dishwasher stopped midcycle, no lights present, and the buttons have no effect.
The power seems to be hard-wired to a switch under the sink. I don’t know if there’s an outlet involved behind the dishwasher, and I don’t know how it’s supposed to pull-out.
I read all the other troubleshooting replies, but I don’t know how to get inside the thing. Should I order the service manual that Joe posted in his first response?
I’m hoping it’s just the thermal fuse, but I have to get to it first!
Thanks!
-Eric
[quote=erf;828353]Hello all..
Thanks!
-Eric[/quote]
Eric, Purchasing the service manual, would be a “good idea” especially if you think you may need it.
Accessing the thermal fuse, isn’t that major a project. Remove power to the dishwasher(your situation sounds a bit strange) remove the inner door panel,
remove the control panel shield, and there it is, to test, or replace.
In most cases, the outlet under the sink, has two outlets. The upper outlet is usually for the garbage disposal and is controlled through the switch on the wall. The lower outlet is usually a constant 120 VAC power supply, and the dishwasher power cord is usually attached to it.
Of course there is the possibility that there is a completely separate power supply to the dishwasher from the breaker panel, as well. You’ll need to determine which power supply system you have before you start anything.
Hi Joe…
Thanks for your reply. I guess what confused me were some postings that talked about “taking six screws out from the top…” and I wasn’t sure the top of what. I found a video on YouTube which covered it pretty well.
The power situation may be strange, I don’t have much to compare it too. Both the disposal and dishwasher have power cables going into a box with two conventional switches on it. One switches the power of and on to the disposal, the other (I assume) does the same for the dishwasher. So I should be able to turn the power for the dishwasher off from there.
I ordered the fuse, so when it arrives I’ll have at it. I just hope there aren’t any other fried wires to deal with, as has been reported in this and/or other threads.
Thanks again!
-Eric
[quote=erf;828638]Hi Joe…
Thanks again!
-Eric[/quote]
Eric, Don’t count on the wall switch turning off the power to the dishwasher. Make sure you unplug the power cord from the outlet, or turn the breaker off at the panel. Be safe… Not shocked … Glad you found the video, they are pretty helpful, I prefer to remove the inner door liner, instead of just the control panel , there’s more room to work, and if there are damaged wires, access and repairs are a lot easier. Repairing wires is not that major a deal these days, needed parts are available at any hardware or home improvement center or auto supply dealer. Connectors, terminals and crimpers are relatively inexpensive, if needed at all.
Sounds like you’ll do fine.
[quote=Joe / APP Team;828694]Eric, Don’t count on the wall switch turning off the power to the dishwasher. Make sure you unplug the power cord from the outlet, or turn the breaker off at the panel. Be safe… Not shocked … Glad you found the video, they are pretty helpful, I prefer to remove the inner door liner, instead of just the control panel , there’s more room to work, and if there are damaged wires, access and repairs are a lot easier. Repairing wires is not that major a deal these days, needed parts are available at any hardware or home improvement center or auto supply dealer. Connectors, terminals and crimpers are relatively inexpensive, if needed at all.
Sounds like you’ll do fine.[/quote]
Well, I’ve come against a (hopefully minor) block… I got the dishwasher door cover off, but all the electronics are in a black box that, at first glance, seems to be secured pretty tightly to the door itself. There looks like there may be some tabs holding it on to the door, but I didn’t have a chance to poke and prod it at all. I’m afraid if I force the tabs, they may break. Does this sound familiar at all?
Thanks!
Hello
I’ve recently found astomishing
haarausfall stoppen
