Whirlpool Portable Dishwasher is clogged
My Whirlpool Portable (Free-Standing )Dishwasher
is clogging and will not drain.
I need some help in clearing the clog
and a diagram to help me figure out
where I should be looking.
The Whirlpool owners manual is not very helpful.
Thanks.
Disconnect the drain hose from the check valve (#15 on the diagram), unscrew the check valve and check it inside.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL DP920PFGQ4 | AppliancePartsPros.com
[quote=Gene;102174]Disconnect the drain hose from the check valve (#15 on the diagram), unscrew the check valve and check it inside.
Gene.[/quote]
Thank you very much for the help
and I do appreciate a starting point
on where to look..
I will let you know what happens.
Disconnected the drain hose and check the valve
and it is draining and not clogged anymore.
With grateful thanks and appreciation
for all the help!
You are welcome. I’m glad it was that simple.
