After using the self clean option on the oven, when I tried to use the oven later the elements would not come on, everything else looked like it was working except the elements would not heat. Any suggestions?
Don’t use self-clean.
If you’re thinking of using self-clean see #1
self-clean uses temps at about 900F+. that can cause problems with connections, electronic controls, ect.
try checking /re-seating all the wire connections.
