While preheating, the lower oven element in my old Whirlpool actually melted in one spot to such an extent that the lights in the house started flickering up to the point that the element completely melted into two pieces (broke). When the flickering lights caught our attention, the oven was glowing red inside and putting out a lot of smoke. I am curious about the cause in order to lessen the impact of repair parts. Is it possible that the element melted at a weak point due to a scratch or other defect at the spot of melting, or, did the element melt simply because the thermostat failed to shut down the unit and then subsequently melted down at the weakest point. The cost of a new thermostat is $108.00 for this model and if I don’t need to replace the existing one, I would like to save the $108.
Replacement parts for WHIRLPOOL RF315PXXN1 | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203181470.pdf
[COLOR=“Blue”]Is it possible that the element melted at a weak point due to a scratch or other defect at the spot of melting, or, did the element melt simply because the thermostat failed to shut down the unit and then subsequently melted down at the weakest point.[/COLOR]
It is really hard to make a call on this.
Did you notice if the whole element was glowing bright red or just part of it or just where the fault was.
I know, I probably would not have noticed as I would be in a panic to shut the unit down.
If it was the whole element glowing I would replace the thermostat.
I am assuming you were able to shut it down by just turning the temp. control.
If yes then at least you know that the thermostat’s contacts are not welded together.
Sometimes an element can fail at the feet, this then provides a path from the element connection through part of the element down the foot and to the frame. This is 120 volts but is not controlled by the thermostat so will run wide open.
Be sure to unplug the unit when working on it, 240 volts is lethal.
I would disconnect the thermostat wires and check the contacts in the thermostat. Use the lowest setting on your meter and short the leads together before measuring so you know what a true 0 ohms reading is.
Some meters have a small 0 reading offset.
Measure 1 to 2 and 1 to 3, both should be 0 ohms if not it is an indication of dirty or pitted contacts which can cause the contacts to stick closed.
You could also remove the thermostat and then take it to another oven, place the capillary end in this oven and monitor the 1 to 3 contacts (bake) to see if the open close reliably.
Hopefully others will jump in with opinions and suggestions.
Perhaps the $108.00 is wirth it just for your peace of mind.
Thanks for the quick feedback. Entire oven was “glowing red” as my wife tried to describe. She did shut it off with the oven selector switch; not with the temperature selector - too much smoke and excitement! The element has actually melted in about a 2" section and looks like it has become vitrified into glass. I will check the thermostat as you suggested (I do have a meter).
