Whirlpool Oven Light Blinks On And Off
My Whirlpool Stove’s Oven Light Blinks On And Off When The Stove Is On. If I Try To Loosen Or Tighten The Bulb Nothing Changes. If I Take The Bulb Out, The Stove Does Not Work. When The Light Is Blinking, All The Burners Work And The Oven Works.
Replacement parts for RF364PXMQ models | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%209757347.pdf
Has the unit always done this or is this something new?
Sounds like you have a loose or bad connection somewhere and the control board is getting power through the light bulb.
You did not say if the door switch or light switch must be on/off for this to happen so the problem may be one of these switches.
Unplug the unit and check the connections at the terminal block.
Especially the neutral wire to the control board.
Make sure the ground strap is connected properly is it is a 3 wire hook up.
Make sure that it is removed if it is a 4 wire hook up.
