I run my oven and it works fine for a few minutes and then all of the sudden error code F3 E2 pops up on the display. I replaced the Oven Temperature Sensor and it did not make any difference. Any ideas?
Parts for Whirlpool GR465LXKS0 Range - AppliancePartsPros.com
Could be the control board is giving a false error and needs replacing.
I am assuming that you have already removed power from the unit for a couple minutes to see if the control will reset itself.
But before doing this I would do the following.
Use a oven thermometer and check that the oven is not actually over heating.
Disconnect the plug at the control board and check the oven sensor at the this plug. You are looking for a higher than specified resistance re: could be a problem with the wiring going to the oven sensor.
Below is a link to info on the resistances, check out 7, 8, 20 and 21.
http://www.applianceaid.com/electric-range-repair-topics.php
If it is OK there then check the connection on the board.
Check that the pins are clean.
Check for a cold solder joint at the pins for the oven sensor. Cold solder joints are often a dull gray and may have pin holes. Also if you wiggle the component you may see the leg on the solder side of the board move in the solder. A magnifying glass helps when doing this.
If all OK then I would replace the control board.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
GR465.pdf (252.8 KB)
