My double oven stop working a month ago. After I have changed thermal fuse and control panel, it worked, for one night! The next morning, it stopped working again. I checked to find out the fuse is out and I remembered that the R90-92 to be hot. So I order a control board and new thermal fuse. I put them back tonight and it worked! However I found that the parts R90-92 were pretty hot, and I am afraid that something else is wrong besides the board. Should these parts be hot? Is there a way to check? Thanks in advance!
I cannot be of much help here as I cannot get a schematic of the board so I do not know what circuit those resistors are part of.
Manufacturers do not publish them.
I can give you the tech sheet in case you do not have it.
This may let you trace back from the resistors to see what components they control.
Thanks! I was trying with these but unfortunately couldn’t figure out. I do realize though that I didn’t do the program Cavity size, would that be a reason? The other common thing I seems to get here is the transformer, would that lead to the problem I have described?
