Hello. I need to replace the outer glass on the lower oven door because I broke it. I was told by a representative that I need Part Number: AP3837648
However, before I order, I need to know how to get to the glass. I removed all the screws that I can see (door is still attached) and the front part isn’t budging. There appears to be two brackets on the inside that i guess holds on the handle. I can get to two of the screws there but there are two more that I can’t get to. Do I need to take the oven door off to do this repair? I am at a complete loss and incredibly frustrated.
Yes remove the door and place it on a blanket or a couple towels on a table or counter see Page 2-3 in the manual. This will make the job much easier.
I would put some if not al the screws back in before removing the door, you do not want it to fall apart as you try to remove it.
