I know my motor coupling is bad. Part #13 on most schematics online. However I’m not sure if it was caused by the gearcase seizing up. Inside the tub I can no longer spin the lower portion of the agitator by hand. Also underneath where the gearcase attaches to the coupling the shaft, it spins very freely by hand. I’m thinking to easy. Basically on one end of the gearcase it spins freely but the other end does not. I almost forgot to say I had the “pleasure”…of being nearby when the washer made a noise, somewhat as a grinding noise as in gears grinding. At first I thought it was the coupler going bad but now I’m not so sure. I know, not good. Am I overlooking something? The motor coupling repair seems to be an easy and inexpensive however the gearcase seems to be somewhat more involved plus the cost factor.
My questions are:
Do you think my gearcase is bad or is the resistance through the gearcase too much to move by hand?
How involved is replacing the gearcase? Special tools, pain in the butt…
Do you think it is not worth the possible cost of replacing both the coupler and a gearcase on a washer that is 15 years old?
Thanks for any and all opinions, recommendations or insight.
