Whirlpool microwave vent fan not working
my vent fan just stopped working, the display says the fan is on but nothing happens.
The problem could be a bad fan motor or a bad control board.
Perform the troubleshooting as described in the service manual (pages 7 & 10).
  • The part number for the control board is AP3951232
  • The part number for the fan motor is AP3964272
P.S. The above link does not work any more. The tech sheet is attached to the post.
Tech Sheet - 8206560 _ MH2175XSQ0.pdf (592.9 KB)
Whirlpool MH1150XMT-0 Fan will not run when oven is on unless you manually press fan and then only on high. No low speed. Bad door switch ? fan hi low switch or relay?
Hi Edwards,
Most likely the problem is a bad control board.
Here are the break down diagrams for the Whirlpool microwave Model MH1150XMT0
The fan on our Whirlpool Microwave MH2175xsq0 stopped running today. When I try to manually run it the word SOUP appears on the display. The rest of the functions on the control panel work fine. Down to the fan?
Sounds like the problem is a bad control board, but you may want to perform the troubleshooting as described in the attached tech sheet (page 7 & 9).
Here are the breakdown diagrams and Replacement parts for Whirlpool MH2175XSQ0 Microwave Oven 1.7 Cu. Ft. | AppliancePartsPros.com
