**Brand: Whirlpool
**Model Number : WOC54EC0AS04
**Main Symptom: oven not heating since I did self clean
**What happens & when:
Hey,
I used self cleaning recently and now my oven won’t heat up.
Any solution pls!!
**Brand: Whirlpool
Hey,
Any solution pls!!
You will want to access the control board and then set the unit to bake and test to see if there is 240 Vac coming from the control board to the bake element. If there is proper power then this will be a faulty element and if there is not proper power then this will be a faulty control board. Whirlpool W11035599 Electronic Control Board (AP6039137) - AppliancePartsPros.com
So, from a chat group I figured it mostly could be thermal fuse issue. Bcs I started seeing this issue after since I did self clean. Would you mind letting me know which thermal fuse part I should replace my model with??
This unit does not have a thermal fuse in the oven circuit. It has one that would cause the display not to work but not for the oven circuit if the display is working.
Oh I see, the display still works in my case.
