There is a ticking noise coming from the ride side, behind the keypad. When you run it, it will start ticking immediately then stop after 3 seconds. Thing is about 15 months old. Doesn’t matter how long you set the time for, stops after 3 seconds. Any thoughts?
Remove the upper grill and then remove the screw in the top of the control panel. Carefully lift it up and out. Start the microwave and see if you can get a better idea where the ticking is coming from.
The only thing on the inside it a white cover with four screws. I took that off and there is just a hole there that leads upward. I cannot figure out where the control panel access is on this thing. It is an over the stove model so there aren’t any real panel access on the sides and bottom. maybe it is on the back?
