This is over the range microwave with everything working on it except the internal fan does not run. The vent fans work fine. I opened the microwave
and tested the fan by disconnecting it from microwave and directly supplying 110V to it. The fan works fine independently.
Unfortunately Whirlpool is very inaccurate when it comes to name of parts. It is very often when you can see the same part called different names at the wiring diagram and parts list.
