Hey all, my KitchenAid fridge (KRMF706ESS) has been making this intermittent knocking/pumping noise every so often (couple times a day) and will last anywhere from 5-20 mins. When the sound is happening, I can’t dispense water.
Not sure if it’s coincidental, but about a month or two ago, the cooling went out everywhere… had to power cycle and pull it out and cleaned up the dust. It has been fine ever since.
[quote=bldrco;921944]Hey all, my KitchenAid fridge (KRMF706ESS) has been making this intermittent knocking/pumping noise every so often (couple times a day) and will last anywhere from 5-20 mins. When the sound is happening, I can’t dispense water.
[quote=cfaber;921951][quote=bldrco;921944]Hey all, my KitchenAid fridge (KRMF706ESS) has been making this intermittent knocking/pumping noise every so often (couple times a day) and will last anywhere from 5-20 mins. When the sound is happening, I can’t dispense water.
