Whirlpool Imperial series 465
One of my burners isn’t working. What parts do I need and how do I get the glass top off?
Thanks.
Replacement parts for RF199LXHQ models | AppliancePartsPros.com
Here is a manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/5feedbe46138625985256aa1005ef62c/$FILE/8178042.pdf
Could be a number of things the element itself, a bad infinite switch or a wire burned off.
Remember to unplug the unit when working on it, 240 volts is lethal!!!
